2010 E-tech 150 shift rod
jakedaawg
Take off lower port engine cowl. You will the see shift rod connector and pin.
Grub54891
Will do Jake! I did try to look it up online, but came up empty. I thought about the lower cowl also, But thought they would not put it under there.
Grub54891
Thanks again, removed the port cowl, and there it was. Got it done in short order.
