2010 8hp 4 stroke carb issue
yellowbelly
gotta order some parts for the carb.. motor starts and runs ok after 15 min at idle it will stall then its a pain to start again.. last week i noticed the rubber boot on the what i assume is a accelerator pump was torn i replaced that but gas still comes out on top when i press the primer pump on the motor..i see in the parts list there is a check valve and the plunger...would the check valve cause gas to go past and come out the top of the boot..in the pic is where the gas is still coming out
