2010 115 etec overheating
LoganHaas
Have a 115 Etec Evinrude. Used to overheat whenever going into plane, getting speed. Changed full water pump kit, both T stats. Issue went away with 3 or 4 people max in boat, occasionally overheated at speed with 4, rarely. Thought problem was solved, took 7 people out, overheated whenever getting onto the plane, 30 secs into getting speed. At a loss of why.
jakedaawg
Vessel under powered? Too much prop? Incorrect trim adjustments? Incorrect height? Fishing graph Sounders located too close to lower unit? Improperly loaded vessel/poor weight distribution? The list could go on and on...
Does that motor have a poppit valve? Did you rebuild it?
Is the compressor overheating?
LoganHaas
I think it may have something to do with the pressure relief valve spring being too stiff. Supposed to open at 21PSI but Evinrude came out with a improved one that opens at 19PSI.
