arkansasboatman
Thread starter- Joined
- Mar 8, 2004
- 9
Hello all<br />I have a 2002 200HPDI that has an unstable idle. This condition started after replacing the power head. Have replaced seven other 200HPDI power heads with no problem. The engine starts and runs fine at all speeds and does not die at idle. <br /><br />Problem; for no aparant reason the engine will gradually increase idle to about 1500 rpm then fall back to 700-800 rpm. Watching the laptop while running YDS, the timing appears to be leading the RPM increase. The timing increases also during the increase of rpm. This will happen during the entire time the engine runs. I have varified all of the sensors, changed the injectors, changed the thermo sensor, replaced the connector for the thermo sensor with Yamaha bullet connectors to make sure I was getting a good signal from the thermo sensor. The O2 sensor housing has been cleaned and O2 sensor changed. All of the settings displayed in YDS are normal. There are no fault codes. During the power head change the throttle body and reed valve assemblies were thoroughly inspected,cleaned and torqued at assembly. Throttle valves were syncronized and TPS set. All new gaskets were used. I have spent many hours working on this problem and am stumped. Any help will be appreciated.
