Hi guys I need some help with this 200 hp that I’m working on the std side had low compression so I pulled the head off to see what was going on with it. Once I pulled the head off I noticed that the gasket had failed and the water passages where all blocked my question to all of you is what is the best way to clean it out on the block side and do I need to get the cylinder head Machined and where to find the parts that I need to fix it
also if some can help me with the engine numbers that would be greatly appreciated j200txcdr I’m having a hell of a time trying to decode this engine
