atomicthunk
- May 4, 2012
- 2
Pulling my hair out trying to find what's wrong. Have no power to the ignition switch. 50 amp breaker is okay., do not have 90 amp fuse on the starter. I either don't have or I am looking in the wrong place for a possible 20 amp fuse in line with the ignition switch. All fuses in the fuse block are good. 50 amp inline fuse on plus battery wire good. Blower, bilge pump, tilt/trim, horn all work. When turn the key nothing happens, nothing to the gauges and no click at the starter. What am I missing. Did all the normal things like cleaned all the battery connections. I'm lost. The only thing I haven't checked is the "run" switch and neutral switch. because I am not sure how to get access to them. Any ideas, hoping to find someone that has been down this path before and found the fix.
