2008 Mercury 90hp 2 stroke fueling issue
robert graham
Re: 2008 Mercury 90hp 2 stroke fueling issue
When you first had the problem did you check your under cowl fuel filter for water or debris, just to get an idea of what may be in the system? Also, you're gonna need a fuel/water separater to help prevent these problems in the future. Also a good idea to drain carbs a few times per year since water, debris, fuel varnish tends to collect there in the float chambers. Good Luck!
