mdaddy
Thread starter- Joined
- May 16, 2019
- 65
Serial#: 1A233107
In the process of replacing both trim/tilt switch/sensors... initially drive would only go up, so cleaned them, worked ok for a minute then failed again. Question on the right side switch (sender) there is a white disc with contact as on it inside of the sender unit, what is it called and what does it do. After removing the sender, I seem to have hid this part from myself as I deemed it very important! Thanks guys!
