jerryjerry05
- May 7, 2008
- 17,926
Model DF25 02502f 8825
The port cyl. is covered in oil.
Comp is 180X2
Won't fire on port cyl.
Will run on the stbd.
Good spark on both plugs.
I believe the valve stems seals are leaking.
Anyone run into this kind of problem?
My cutomer just bought this boat after it
sat for 10+ years.
From the looks of the piston it burned a LOT
of oil when it was first new.
The motor looks absolutely brans new.
Not even a scratch on the skeg.
Thanks.
Comp is 180X2
sat for 10+ years.
Thanks.
