2007 SeaRay 185 3.0 Mystery Hoses
kanada
Got bank repo 2007 SeaRay with 3.0.
What was connected at the end of these cooling hoses? Everything else seems to be in tact. one hose is connected to water hose, other to the block.
Thanks!
Grub54891
Must have been a water heater in it at some point. when ya turn on the motor does water come out,or is it hooked to the fresh water pump? If hooked to the motor it should be blocked off.
Bt Doctur
those 2 hoses are the block drain and the manifold drain. look on the port side for a bracket they plug into.
Ayuh,..... Yet another Merc idea that'll cause lotsa cracked blocks,.....
