2007 Mercury 25 EFI 4 stroke problem NEED HELP PLEASE
Status
Not open for further replies.
bartowski
Hello,
I bought a newer model motor (2007 Mercury 25 HP 4 stroke ELPT) as I am not too mechanically inclined. I am capable of doing minor things and can follow instructions pretty well, but I cant rebuild an engine or anything. Last season when way out on lake Erie trolling my red warning light came on and there was a constant beep at my throttle box. I shut off the engine but couldn't figure out what was wrong. I noticed that if I was driving at a faster speed the light wouldn't come on, only at lower speeds. I managed to make it home, and took apart the lower unit to get at the impeller. Right away I found out this was my problem, as the impeller was all warn and broken to ****. I put a new impeller in, and the motor was peeing like crazy! No problems for the rest of the season....
Fast forward to this year, after running the boat a few times the red light came on again and the constant buzzing. I shut the motor off for a few minutes, turned it back on, and it didn't do it again. So I went trolling around lake Ontario. On the way home I noticed half my power was lost. It was moving at about half speed. A local mechanic suggested it might be my thermostat, so I went about locating it and took it out. I tested it in hot water (both boiling and 63 degrees since its a 60 degree thermostat. It appears to open slightly at 60 degreees and a lot at near boiling water. Thus I have wasted time removing the thermostat and what was once a good gasket. I have no idea what's wrong at this point. My mercury manual (not a service manual which I cant find anywhere online of course) says that the constant beep and red light, along with loss of power is an over heating problem, but my motor is pissing out a lot of water as normal, and the thermostat appears to be new.
Anyone have any other suggestions?
If I cant fix this myself I will be forced to bring it to a mechanic, although money is an issue right now.
Thanks
carholme
Re: 2007 Mercury 25 EFI 4 stroke problem NEED HELP PLEASE
Firstly, what is your engine s/n?
Gerry
bartowski
MOTOR S/n: OR229405
Thanks
Rsb1970
I know this is an old thread but did you find out what’s wrong? Mine started doing the same thing this year. Twice so far.
GA_Boater
You know the bad thing about asking questions in an old thread? The answers never come because the OP and often the helpers aren't visiting the forum any more. And you get PO'ed because your questions are ignored. :doh:
Start a new thread! Closed.
Status
