2007 centurion c4 lightning black scorpion engine
Konger10
On my boat after I get it warmed up good and at idle 650rpm I get an alarm goes beep and engine rpms drop along with oil pressure like motor stalling out. Then it catches itself and everything come back up as normal. Only does it at idle bring rpm off idle it does not do it. What could this be. Thanks for any help
alldodge
Could you revise this comment?
Could also use an engine serial number.
Is this a solid beep of just a quick one? Any more comments of what is happening could help
Konger10
It is just a quick beep rpms drop like going to stall out then jumps back up to idle. It the same beep that goes off when I turn key on to start
Konger10
If I bump up rpms off idle to 900 it does not do it only does it at idle. Boat runs great besides that. Do not have engine series number at this time boat at lake I at work
alldodge
Don't know why its so hard to get info from folks wanting help.
The black scorpion comes in a 350 mag and 6.2 versions, also different serial numbers are used based on parts used. Most the stuff is the same but not all.
Look for a vacuum leak, there are hoses going from the plenum to the fuel pressure regulator. Check the IAC for build up and remove IAC muffler to see if its clean
http://www.mercruiserparts.com/bam/subassembly/31447/10108/80
alldodge
OK, that is a piece of info that helps. This makes me think even more it may be the IAC being gummed up. It reacts but not fast because of some crud. Need to have a look to find out
