Hi
I have been having power connection issues this season and I was told I should check the boat ground conection point. I have no idea where that is though. I took apart my battery switch cleaned it up and wire brushed all the wire lugs and now everything seems OK, but I'd like to check the ground just in case before I put it in the water.
My issue was one day I could fire up the motor and everything powered up fine, the next it was like the battery was dead. (Both batteries). I had both checked and they are fine so I'm pretty sure it's a connection issue. It may have been the switch and is now fixed, but I'd just like to be sure. The switch had some black gunk and moisture on the contacts. I cleaned it off and spread around some of the extra grease and it seems OK now.
A friends boat has a large brass or copper piece on the bottom but I don't see anything like that on mine. I'm worried now that it's been painted with bottom paint and maybe that the wire connection had some corosion on it.
Does anyone know where it might be on my boat and what itb looks like? Does the ground wire off the batteries go to the motor or to this ground point first?
tThe motor is a 90hp Merc 2 stroke if that matters
Thanks!
Mike
Thanks!
Mike
