2006 Optimax blowing fuel pump fuse
lemons3250
Hello,
I have a an optimax that blows the fuel pump fuse when the key is turned on. I have checked relays, checked grounds at the engine, checked connectors. So looking for additional troubleshooting ideas.
dingbat
Hello,
Pull connector on fuel pump.
If fuse doesn't blow when you turn the key, you have a bad fuel pump
lemons3250
Thanks! I got it figured out yesterday. The fuel pump in vapor separator was bad causing the fuse to blow
