I can make the tilt trim go down but not up. The relays are activating and I can get +12volts at both the motor wires, separately by using the switches. can run the pump up and down powering directly from the battery. Initially thought bad relay but no change with a new relay. This motor could have been messed with so the wiring at the relays may be incorrect. The two wire motor needs to have the polarities switched to change direction this I know. Does anyone have the wiring schematic for this one or can advise me.
