2006 merc 15 4storke Please Help :(
G
Guest
Guest
I have a 06 merc 15hp 4stroke short shaft. . One month ago i got stuck in the water when ever it started it rev's really high then shut down. I got home cleaned the carb/ changed coil (thought it had to do with spark for some reason) changed fuel line and bulb an even changed the diaphragm in the fuel pump. But i cannot get the engine to run smooth on muffs. It vibrates super hard and i hear it running rough. It does run though. I checked compression and i got 187 top and 185 bottom cyl. Checked fuel lines and filter. What can it possibly be? can it be timing? why would timing get messed up?
Thanks for your help everyone!
