2006 Larson Cabrio 240
Rob flan
Just purchased a 2006 Cabrio 240, First time we took her out, hooked up to shore power, ac came on perfectly. That night we were ready to settle down, She kicked on but no water dispersing from the side, she wouldn't get cold. Is there a technique, maybe I have air in the lines..... Need advice... Thanks
jforrest1
Just want to make sure you had temperature adjusted to colder than the panel was reading. Unit will run and no water will discharge until compressor kicks in. That’s usually a degree it two less then temperature reading on display. You’ve probably figured it out by now... happy boating with your new Larson!
Rob flan
Jforrest, I haven't taken her out since this post, but were going to Bay Saint Louis Mississippi for Cruising the coast this Friday... So my display isn't digital, so I don't know what degree its at.... But I will definitely give it a shot, Cool front coming in Early sat morning, but I may need some air Friday night.... Thanks so much for the advice...
