2006 Evinrude 225 E-tec
donnyskz1
I Have A 2006 Evinrude E-tec That I Had Put On In January 2007 Is Was Installed As A New Motor. I ONLY HAVE ABOUT 83 HOURS ON THE MOTOR. While I Was Out In The Boat On Saturday I Started Having Problems With The Engine. We Were Cruising At About 30 Mph And The Check Engine Light Came On I Stopped And Looked At The Cover And Saw The 4 Led Light On The Computer And From The Top One Down The Third One Was Light Up From What I Gather From Reading The Sticker On The Back Of The Computer It Was A Sensor Acting Up. The Boat Stayed Running Fine Though. A Little While Later The Hot Light Came On When That Came On It Slowed The Engine Down. Then That Light Went Off But The Check Engine Light Stayed On. A Little While Later The Low Oil Light Came On I Checked The Oil Tank And It Was Almost Full. When That Light Came On The Engine Starting Running So Bad That We Had To Be Towed Back To The Launch. The Engine Was Runnign Like It Was Starving For Fuel. When I Check The Primer Ball It Was Very Soft. When I Finally Got Back Home I Put The Muffs On The Engine And Started It Back Up It Ran Rough Like Not Getting Enough Gas For About Five Minutes And Then Started To Run Fine I Left It Running With The Muffs For Abut 45 Minutes And Everything Was Fine. The Check Engine Light Did Not Come Back On Either While At The House. Has Anyone Ever Had This Kind Of Problem Before
