2006 90HP ETEC Saltwater Edition Problem
deff808
I have a 2006 90HP ETEC Saltwater Edition
On the engine itself, the button to lift up the engine, up and down, works fine.
On the throttle, the up and down control doesn't work, to lift up the engine.
Ignition, check engine light *beep* etc... Does not work. While the key is in place to turn.
Engine does not start
I took my boat out last week, it worked fine.
Just today, when i wanted to go fishing. Nothing works
Ground? Loose connection?
Fuse in the engine is fine.
I have no clue!
oldcatamount
Re: 2006 90HP ETEC Saltwater Edition Problem
Sounds like a blown fuse to me, but I know nothing about E-Tech motors, so I won't be able to help you much. I do know, that the electrical system is very complex, so you may need your dealer to help with the problem. Can you access the fuse panel at all? Might be worth some exploration before you head to the shop, but I doubt it'll be that expensive (if you're working with an E-Tech mechanic that has some experiance with that sort of thing).
boobie
Check ALL of your pos and neg battery connections on the batttery and mtr first for being tight and clean. You may also want to have your battery load tested at a local parts house.
