2006 70 hp yamaha 2 stroke power loss
exumaboater
Help!
Recently brought a 70 horse yamaha back to life with new parts and elbow grease. This thing runs so great. Turns over on the slightest flick of the switch and just hums at idle. only problem I have is that it cant stand a load (all the time). Sometimes I can coax it up on a plane but it takes finess and timing. Everything fuel related checks out. I went through the carbs already and they were like new, now clean and new. I replaced the relays, fuel pump, new plugs gapped properly, starter accelerator, wiring harness, ignition switch, coils for cylinders 2 and 3, and cleaned everything thoroughly. All of these parts had been stolen from the motor before i got it. Compression even on all Cylinders. It looks like only Cylinder one is doing anything. I warmed the motor up on the earmuffs, removed the #2 plug wire and there was no change at all in the RPM's. Did the same to the #3 plug and no change. Removed #1 and the motor shuts right off. I am told it could be the stator or the CDI. Looking for insight on where to go from here. I live in the bahamas and dont have access to a manual but am familiar with 2 stroke systems. Any help would be appreciated.
Exumaboater
exumaboater
Re: 2006 70 hp yamaha 2 stroke power loss
Took the boat out this afternoon. Able to get on plane, again after coaxing it. Seems like it eventually gets to running on all three cylinders. I am getting about 22 knots out of it. what am i missing? Surely I cant plane on one cylinder right? Again, any help would be great. Has to be CDI or stator, right?
passingwindII
not so sure with your motor but i had similar problems with mine. being the no power but sounded great. mine turned out to be pinched wires grounding out. makesure you can tug wires and see them move on the other side.
exumaboater
Thanks,
Ill check the wires for binding. Im from Wilmington. How is Hampstead treating you?
