2006 15hp johnson controls ?
adominique0313
Hello, I have a 2006 Johnson 15hp pull start tiller. this is not power trim. I would just need fwd,rev, throttle and kill switch. I will be hooking it to my 90hp for turning. The question is I would like to put controls on it instead of tiller. I am having trouble finding the control I would need (has to be side mount) and the cable I would need? I have found a control I like but don't know if would work. I will try to attach the link
http://www.ebay.com/itm/Teleflex-CH2...1T5aHP&vxp=mtr
My boat is not a sail boat but has limited space. If you have anything better you think would work better for me please let me know. I would also need to know what cable to buy...
thanks again
oldboat1
I would look at this kit: 5036662. You can find here at iBoats with a parts diagram -- diagram is important, because you are probably going to end up buying parts separately: http://www.iboats.com/KIT-AY-REMT-CONTL/dm/cart_id.364598833--session_id.240124146--view_id.1502802 You do not need a wire harness** or steering parts. You need all parts related to attaching shift and throttle cables at the motor. You need a couple of cables for post-'79 OMCs, and a control box. The box can be a simple one used only for cable operation.
**If sure you need a kill switch up at the box, you will need to wire that -- better option is to just leave it at the motor, but your call.
Honorary Supreme Mariner
Is this motor a 2 stroke or a " Johnzuki " 4 stroke motor.
