2006 15 hp Johnson copper tube water pickup...NEED HELP.
BenjaminC
I have a J15RSDR motor. I bought a lower unit for it. I am converting it to a long shaft from short shaft. I have all that I need, except the copper tube in my midsection currently is not long enough. I call a mechanic and ask how to remove the current copper tube and replace with longer one as needed. I was told "just pull it out, it will slip right out, no problem" WRONG, IT WILL NOT. in the mean time I have completely destroyed my copper tube that is in the motor now, so I am fully committed, I have to get it out. Somebody please help me....i need it...."aw just pull on it, it will slip right out"ugh.
Daviet
Re: 2006 15 hp Johnson copper tube water pickup...NEED HELP.
Sounds like you are going to have to pull the power head. There is a grommet on the water tube, now you can install the water tube and new grommet. Check the outlet water tube grommet while you have the power head off.
BenjaminC
Ok, I have never done that before so, what is the best plan of attack?
Haffiman
1:Remove engine side covers, remove powerhead from leg, remove exhaust tube and you may pull out the tube the right way!!
2: Make a bill and send to the mechanic that told you 'just pull it down'!!!
