2005 Yamaha 225 Power tilt Trim Troubleshoot
nic420
Will not trim up or down when button is pressed. Makes noise when button is pressed. Sounds like motor is still working. One of the ram was stuck but now freed. Oil is milky color. Please assist.
99yam40
water in fluid if milky looking
need to rebuild to stop fluid leak and to seal water out
nic420
Pressure tested and no leaks. Just need trim motor oil changed/filled. All good now. Thank you.
