2005 Suzuki DF140 overheating..Back pressure
Status
Not open for further replies.
mobileguy
Hoping someone can help me out. The motor is definitely overheating. I have replaced impeller and performed compression tests on cylinders. Pressure is OK. I have replaced thermostat.
The motor will overheat at Idle. Not sure where to go from here. I'm wondering if I have an exhaust/water issue after thermostat?
The motor will run fine at low rpm's only if I remove the Water Return Hose from the leg/ engine holder(not thermostat end,other end of hose). Is there supposed to be pressure coming up from where the hose connects to leg? When hose is connected it seems like I have to much back pressure preventing water to exit past thermo.
DRRFL2
i am having the same issue with my df140 2005. i have also replaced the water pressure valve, still same problem.
DRRFL2
i am having the same problem with DF140 2005 . Did you get any resolution of the problem?
Status
