2005 Rinker 232 Cuddy...water in Cuddy
bizjets
Boat is parked nose low...found water in the cudddy cabin cabin floor, (an inch or so)...vacuumed it out. Came back next day, more water. I opened the front storage area and pulled the plastic tub to reveal the hull...found water. Vacuumed it out, (probably 30 gallons). Wondering where it came from and if others have ran into this. Boat had the rear plug out and drained. Thoughts?
alldodge
If its on a trailer then it can come from the bilge. If the water tank is full it can come from it leaking
Sitting outside could be rain
bizjets
It is double tarped...I will check the bilge! Thank you!
