2005 mercury 8hp 4-stroke
ckkoch09
Hi, I was wondering if these little kicker engines have trouble pulling fuel thru the inboard fuel tank? My main fuel line is hooked from the fuel tank to a high pressure pump/filter then to the fuel/water seperater. It is then split from there,one fuel line to my 350 v8 and then the other fuel line to my 8hp mercury. I have found that after running the kicker motor trolling for a while it will die. I have to pump the ball to get the fuel back to the engine. (Sometimes) I have to fire up the main engine fuel pump to get fuel back in the lines because the ball won't get it back on it's own. I have been told to carry a spare tank because these engines can't pick the fuel up out of the tank. I have talked to guys on the water with the same set up and they don't have the same problem. Any thoughts would be appreciated.
Thanks,
Chris
quicktach
Re: 2005 mercury 8hp 4-stroke
What's different between your set up and theirs? I'd be inclined to go with a seperate tank for the kicker !
