wave_rider
Thread starter- Joined
- Sep 26, 2011
- 16
I'm on a family trip and we have taken the boat out a few times and it has worked well. Did notice the telltale wasn't flowing well at one point but then started flowing well again so figured it was ok (might need to replace the poppet valve soon, just replaced the impeller about a month ago) Also, I recently changed the thermostat, fuel filter, fuel/water separator, and lower unit oil. We went for a little swim and shut down the motor while swimming then when I started up the engine it started fine but almost immediately the engine alarm went off. I turned off the motor and the alarm started back up every time I put the key to run... Then I started it back up to get back home and the alarm stayed on the entire time, even in idle. It will throttle up fine and the telltale looked to be flowing well. There was plenty of oil in the oil tank, it was 3/4 full. Any ideas or suggestions of things to check, hoping to get back on the water before we head home but not holding my breath. Thanks in advance for any help, really appreciate it.
Engine is a 2005 115hp ELPTO Saltwater
