2005 lower unit 50 Hp
pyroduck
I recentley purchaced a boat that had a 2005 johnson 50 on it. It's a 2007 boat/trailer with the johnson on it. I paid 1200 for it, the only problem is it needs a new lower unit. The one that was on it was aparently so damaged the shop just threw it away. I've been looking for a used/new/rebuilt lower unit but everything I can find cost more than I paid for the whole setup. If anyone is selling a lower unit for cheaper or knows where I may find one I could use the help. Thank you
tashasdaddy
Re: 2005 lower unit 50 Hp
being so new, they are going to be hard to find. http://www.boatmotors.com/motorparts/ or try these.
Salvage yards.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
5150abf
It takes a little work but you will probably be able to find something on ebay, they have the $1800 ones to but you can get a deal if you look long enough.
Find out what other years are compatible, I'm sure it is alot, so you have a bigger choice.
Faztbullet
If its a Etec series 2004-2007 40/50/60hp will interchange, if not a Etec the 1989-2005 40/48/50hp will interchange. My supplier has them new in stock.
pyroduck
Thanks guys found a rebuilt 94 on ebay for 500$, appreciate the help
tashasdaddy
Faztbullet, Evinrude builds Etecs, Johnsons are carbed.
