2005 Larson 240 Cabrio
Gummi
Hi All
We recently boat the above mentioned boat and have some questions around the electronics. So if anyone has a similar Larson I would appreciate your responses.
1. The auto bilge pump in the engine compartment. The rocker switch has 3 positions. Pressed forward turns on the forward bilge pump and I hear it run. In the center position I guess it is OFF. Do I have to have the switch down to the rear to have the auto bilge pump ON or is it ON all the time even in the OFF position. The rear bilge pump doesn't run in either position but that could be due to the float switch not turning on. Any thoughts.
2. Which accessory switch turns on the fresh water pump? I have run a separate cable to the fuse block to get the pump to work as it wasn't turning on when any of the accessory switches were turned on. I would like to have it work off a switch so that I can turn it off at night.
Link to a pic of the dash...
https://1drv.ms/u/s!AsJm1Oae1esbkqNTncur6a-emeAS5w?e=bidgOl
Any assistance would be appreciated.
Rob
