I can't seem to find a scenario that is similar to mine when doing a search, so I figured I'd ask around. A year or two ago, we had an issue with the alarm horn where it would continuously beep at low volume during operation. When starting the boat, it would sound briefly at high volume (the normal power-up test) but then drop to a drone in the background. The tachometer lights all come on and disappear as expected. No codes, no error lights, and no operational problems when the engine is running. This occurs from a cold start and doesn't go away. The water stream from the pump is healthy and not of an elevated temperature. We've never encountered performance issues, limp mode, or any other error beeps as I've read about in other threads.
When I originally inspected the horn, the potting compound had some damage and so I figured maybe it wouldn't hurt to replace it, and the problem seemed to go away, at least for the most part. Fast-forward to the present - we just put the boat in for the season, and the horn is doing the exact same thing as a few years ago. The wiring harness going to the horn appears to be in satisfactory condition, without any visible damage.
For reference, this scenario is occurring on a 20' Suncruiser pontoon, originally equipped with an Evinrude outboard. Not sure if it is relevant, but the key/switch/throttle control unit is the boat's original OMC unit.
My first instinct is that this is caused by a bad ground somewhere. When I've done repairs in the past, I was less than impressed with some of the general wiring on the boat, as it looks like someone decided to use wire nuts to tie things together inside the console. Certainly, there has to be a better way - I suspect the Johnson has a harness of its own, but while I'm asking for advice, is there a standard normally employed on boats such as this for wiring junctions such as common +12V and ground (terminal strips, star ground points, etc.)?
Any insight is greatly appreciated!
