2005 Johnson 150 bogging when warmed up
Cjeby79
Hey guys, I have a 2005 150hp. It starts up just fine when it's cold and I can take off and get on plane and running wide-open down the lake just fine. But then when I shut it off and fish for little bit and try to restart it, it idles okay but smokes a lot and if I put it in gear it immediately starts to bog down and stall out if I try to give it any throttle. So I have to rev it up for a bit in neutral before I can get to go in gear and take off. I also hear a random knock (sounds similar to a rock bouncing around violently inside the motor) when I rev it to a higher rpm in neutral. Not sure if that has anything to do with any of this. I also notice that sometimes the motor idles higher and it slams kinda hard into gear, sometimes when the motor is cold or hot, doesn't seem to matter. Any ideas. And I just rebuilt all 6 carbs. But this problem was there before and after, that's why I rebuilt them. Compression is even at 116 psi on all cyl. It has great throttle response and purrs like a kitten when I get it on plane other than a random stutter one in awhile while flying down the lake.
