2005 EVINRUDE 115 DI runs rough below 2500 rpms
TritonZ
It idles fine and is fairly smooth to 1200 rpm then from there to 2500rpms it seems like its missing and runs rough in general and then once it gets above there and im on plane its smooth all the way to wot. ive tried plugs (indexed properly) cleaning exhaust fitting, decarb, ive even taken it to a authorized service center to be told it was probably just the plugs (had less than 40 hrs on them) and its still the same problem. It seems worse some days than others and ive noticed after running it for half hour then shutting down to fish for a few hours, on restart if your barely advance throttle it tends to drop rpm and bog slightly for 10 seconds or so then its rough for about 45 more seconds even below 1200rpm then clears up again till I get between the 1200-2500 range. sorry for the length of the post but I wanted to best describe this issue so hopefully somebody can point me in the right direction. Model # E115FPLSOD and its on a triton tr175 bass boat.
