I recently bought this motor that has sat for three years. Fixed a shifting problem, replaced VRO fuel pump with non VRO, replaced plugs. Compression running at 130 each cylinder, Checked spark visually.
Right now the motor runs great, on the water, for about 30 minutes then shuts off with no alarm and will only start at high throttle nuetral, and will die out trying to get it in gear. It seems to happen every time when I slow down and my wake catches up to me and water gets up near the exhaust relief tubes. I have not done anything with the carbs yet. It seems to be fouling the plugs. All of this seems to have started with new fuel pump, but has sounding much better with this new pump.
Also, the only other problem that I notice is that water/exhaust leaks near the gasket from power head to housing, but I don't see how that relates to this running problem. Any help is appreciated!
