2005 9.9 HP Yamaha ( Leaking Fuel ) 2 Stroke
Lucky Loser
Tilt motor and gas leaks badly from block or carb. Drop the unit and the gas leaks down to the base of engine, drip , drip , drip. Stuck Float ? Cost for repair ? Thanks. Not sure what to do other than not take it out until problem resolved.
99yam40
Re: 2005 9.9 HP Yamaha ( Leaking Fuel ) 2 Stroke
It is always the best not to run a motor with a problem until it is fixed,as you could ruin the motor or catch the boat on fire if leaking fuel.
Trash holding needle open or stuck float is my best guess. As far a cost you need to call the local shops and ask what they will charge
