2005 50 HP 2-stroke vs 1981 50 HP 2 stroke
Bassn7
2 questions here: 1) Would both of these motors drive the same boat to the same speed? 2) My friends 2005 50HP 2-stroke has a 22 pitch and my 1981 uses a 10 pitch. Why such a huge difference?
Are you sure that one prop is a 22" pitch ?-----Pictures of the numbers on these props ?
Texasmark
The old one is probably running 2:1 with a 13" prop-gearbox setup,whereas the new one may be setup at 2.25:1 on a 13". Course somewhere back there OMC went to the 10" prop-gearbox and ran it at 1.64:1. If you both are running on similar boats, No way will 12 ½% in gearbox change span that disparity. 22 pitch on a 50 hp engine, if they even make one for the 10 inch (prop dia) gear boxes would be running on an 8' tunnel hydroplane or something light and fast, single person minimum weight installation.......buttttt the prop shaft on the 1.64 is turning much faster than the 2:1 so it would be more of a candidate for the 10P for a given load to push.
Agree with racer. Get some prop numbers, on the rear of the hub usually....pull the prop nut and look.
