winbasic
Thread starter- Joined
- Jul 4, 2006
- 125
Hi,
A misplaced step, swell at the wrong time and end result was when I hopped into the inflatable tender it's flipped and the engine cowl has ended up under water. I heard a few bubbles and it took me about 5 minutes to get it upright once I had climbed back aboard my boat. I lifted the cowl and there only appeared to be light 'dots' of water - not liters of it gushing out. I removed the plug, pull started it a few times then put the plug back in and it appeared hydro locked when I attempted to start it.
The next morning, I tried starting it and could smell fuel and then eventually got a few splutters out of it but no longer than about 2 seconds.
So what I figure has happened is the water has gone from the leg back up the exhaust and through an open port. What do I need to do to get the thing running? What do I need to check for? I'm hoping there's some simple steps to resurrect this thing as otherwise I'll have to bin it and get another because the local rates the mechanics charge is going to quickly make it beyond economical repair.
Thanks in advance!!
Thanks in advance!!
