2005 40hp 4 stroke wont spit water
Vortecman07
I replaced water impeller and now the motor won't spit water out of hole on back of motor any ideas?
MH Hawker
yep you missed connecting the water pump tube :D and i know it my self, missed mine twice this last spring
tlewis1
Time to pull that leg again and make sure the water tube it hooked up as Hawker mentioned. Need to watch very closely as installing and verify that the water tube is in place. Run the engine on the hose to make sure you got correct before hauling all the way to the lake.
