Chris_Little
Thread starter- Joined
- Jul 5, 2021
- 6
Hope you guys can help me track down an issue Im having with my 05 Tahoe Q4 merc 4.3
Boat typically runs great but has developed a stalling issue. Took the boat out for the first time a few weeks ago and it had developed an issue where it would run for a few seconds and then die. Appeared to be a carb/fuel issue. Replaced the fuel water separator and took it back out with the same issues. Brought it hope and did some research and bypassed the oil pressure safety switch on the muffs and it ran fine for 10 minutes. Installed a new switch, took the boat out, runs great for a 15-20 min ride, we parked and swam for a couple hours, about 5 mins into the ride back to the launch it stumbles and dies, starts right back up and dies. I brought a jumper wire just in case, hooked that up and made the rest of the trip back to the dock without issues.
Oil Pressure on the gauge is consistent and moves with rpm as it has previous.
Think the new quiksilver switch failed, there is a wiring issue, fuel pump going bad?
Diagnosis plans are to, run the engine on the muffs and ohm test the new switch to verify it is opening. Hooking up a mechanical oil pressure gauge to verify its getting oil pressure. Check continuity from oil pressure switch to the fuel pump.
If you have other suggestions Im open to all of them other than leaving the plug out the next time I back it off the trailer, not there yet.
TIA
TIA
