2005 3.0 Mercruiser not starting
bellmorekennels
Hey guys.
Have a 05 bayliner with 3.0 mercruiser
Started boat few days ago.
Changed out a faulty tachometer
Tried to start today, it cranks but doesnt turn over.
I def smell the gas flowing.
Thinking maybe the kill switch??
Any help guys would be great..
Thanks
Anthony
Fun Times
As a quick test, remove the gray wire from the back of the tach gauge and see if it will start...good luck.
alldodge
Could be, if the kill switch is off the motor will crank but it will not start. The kill switch should be on your throttle handle.
bellmorekennels
Alldodge, I do not know if its flooded.
Just wanted to see how long would be best to waite, if that was the problem
Ayuh,..... Welcome Aboard,..... Check for voltage at the coil,.....
Recheck yer tach install,.... it can ground out the ignition,.....
bellmorekennels
Ok.
Bingo.
Disconnected new tach and she started up.
What would cause this?
It has same connections as old tach
Old tach didnt have any reading
