2005 3.0 alternator belt
bman440440
I have looked all over the place and I can not find a part # for it... I want to have the belt in hand before I go down to the boat... can my iboats family help me out on this please??
achris
More fish than mountain goat
2 different belts fit the '2005' group.
Could be 57-862054Q, or 57-69143Q, although I'm not sure of the difference because the water pump pulley and harmonic balancer are the same for both belts :confused:
Personally, take the belt off, head for the local car parts shop and buy 2. 1 to replace the one you pulled off, and the other to lay in and tie back as a 'spare in place'... It'll be cheaper to buy 2 from the car parts shop than 1 from Merc, and they're the same belt!
Chris........
TBarCYa
My 2008 3.0L uses either the 15400 or 15410 from the auto parts store. The 15410 is a little longer so I typically try to get the 15400 when available.
AMMO DAWG
Not to hijack this thread but does anyone also have a parts store number for an oil filter, mercruiser oil filters are a bit steep, thanks
Ayuh,..... I use Napa 1086, which is 1 of the shorter versions,....
But any standard Chevy oil filter is what ya need,....
