chaddyt150
Thread starter- Joined
- Jan 2, 2011
- 15
I have a 2004 yamaha 2-stroke 40hp oil injected outboard motor and it will not reach top speed. It idles fine and runs good at a low speed but when you hammer down the throttle it stutters a little bit and then will not reach top speed. Every once in a while when the throttle is all the way open it will open up all the way but once you throttle down it will just repeat what it always does. That's how I know it is not reaching it's maximum potential. I have an rpm gauge and when it reads about 4,700 that is when it's maxed out. It will usually run about 3,800 when it's doing bad. Just cleaned out all 3 carbs to see if that was the case. It is not. One other odd thing is the bulb will go soft but even when I pump it up it doesn't matter. Also just replaced spark plugs. That didn't help either. Water is also not in the gas. I have ran numerous tanks of gas and it has always done it. I have narrowed it down to maybe needing a carburetor adjustment or a fuel pump. Any help or suggestions would be greatly appreciated.
