rustysch88
- Apr 18, 2012
- 3
Hi everyone, im purchasing a lightly used 2004 mercury 50 hp bigfoot.. the issue is that it will get hot after running for a little while. the result is that once it gets hot it wont allow you to go full throttle. i dont know much about this engine as i said im going to be buying it.. im curious of the issues i could run in to. i figure impeller but it has really good flow coming out of the water hole.. ive heard something about a seal that requires the powerhead to be removed? also the issue with not going full throttle, is there a safety built into this engine to cut the power back?
Im getting the engine with all controls and tach, has a vengence stainless prop. all for $1250. is that a good deal in its current condition?
Im planning on putting it on a 1999 g3 1544 aluminum boat. its 15.5' and beam is 66" and converting to remote steering.. I would appreciate all input on everything from the cooling issues to your thoughts on this motor and how it will work on the aluminum boat..
