i have an issue where this boat has readings on new manifolds and riser of over 180 degrees,
back story ,the boat was overheating terribly and the previous owner had another mechanic run tests where he pulled the thermostat and "allegedly" pulled the risers for inspection. which he said were fine. i stepped in after that point., running the boat found that there was no water coming out of the transom when running on muffs the boat went into overheat, raising the idle speed caused the hose to blow off of the elbow from the pump to the cooling system. when the hose blew off, the temp went back to normal. further inspection found the manifolds and risers terribly corroded with rust.. (original from 2004) now fast forward to now, i replaced the manifolds and risers, and all seamed well, until i was called and informed the boat temp did not raise above 100 degrees. tests with infrared heat gun found the entire system did not go above 100 degrees including the manifolds. i found that the thermostat was removed and not in the system( which the PO said was replaced) and installed the correct one. after that this issue has arrised. i hope that makes sense.
