steven.swiatek
Thread starter- Joined
- Apr 9, 2022
- 17
Hey yall. So my 2004 mercury ran perfect until one day sucked all of the oil down in a short trip and seized up on the way home (oil alarm didn't work). Cylinders 1 and 3 were scored so I opted to have bored .30 over and rebuild. I also opted to bypass the oil injection (capped off the pump lines) and went with premix for the break in. 2 hours into the break in I held steady at 4krpms for 3 or 4 minutes and all of the sudden lost power. I thought it was ste stator so I used my trolling motor to get home. Replaced the stator and still nothing, so I opted to pull the exhaust and have a look after I did a compression test and got almost nothing out of cylinder 1. Turns out cylinder 1 destroyed itself again. Other two look fine, but in 1 the rings welded themselves to the piston on one side which scored up both sides of the cylinder and piston near the intake and exhaust ports... before I just opt to do a full rebuild again, does anyone have any idea why this would have happened? Thanks for any and all advice.
-steve
-steve
