2004 Johnson outboard engaging in nuetral
Rockyschuck
I changed my oil seals in lower prop unit. Put all back together and started motor. In neutral the motor is engaging forward. WHen putting in forward it stays in forward. When putting in reverse the prop stops like neutral. What did I do wrong putting back together
Sea Rider
Welcome to IBoats,
Which HP model would that be ? When you say that when in neutral the prop engages forward does it spins with load as if pushing a boat or only rotates freely without load ?
Happy Boating
2 stroke or 4 stroke ?----Model # ?----Stop running it and determine what is wrong.-----You may be causing big $$ damage here.
Jaskolski
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue.
Sounds like the shift rod connecter is not properly assembled.----Notches have to be lined up with holes before screw is put in.
