2004 Johnson OB 140 HP- Wont go forward or in reverse
BassMaster76
I have a 2004 Johnson 140 HP OB Motor. I believe this is or was bought out by Suzuki. Anyways, I was driving boat and then all of a sudden it stalled. I restarted motor and it idled fine, but when I put it in either forward or reverse there is move movement. So my boat runs just wont go into gear. Any ideas on where I could start to look for my issue? is this a linkage problem or something in my lower unit maybe? I am clueless and hope someone has some advise.
Joe Reeves
I believe the above highlighted type is a typo which was intended to be worded as "no movement"... just making a note of that.
First... Remove the hood and check to see that the engine's shift linkage moves when you shift at the controls/// possible broken inner shift cable, etc.
Second... If the engine shift linkage and remote shift control setup is as it should be, that leaves.... a missing prop... or a broken, sheared drive-shaft.
Strange that this would happen in relation to having the engine stall.
ob
First thing to do is remove the engine cover and locate the shift linkage and inspect. Have an assistant spin the prop in direction of rotation and try shifting the throttle lever while observing the linkage that attaches to the shift arm and note whether it is actuating the shift arm forward and reverse. If not , your problem could lie within the control box or the cable itself may be parted. This is just a starting point.
Ooops...sorry Joe ,we must have been typing near the same time.
ob
No problem OB..... the more, the merrier so to speak. It appears that we are like minded. (Joe)
Well I appreciate that vote of confidence Joe. :) However ,you're still sort of "the man":hail: , so to speak,in my book on these repair forums
BassMaster76
Thank you to both of you. Joe, good catch on the typo. I checked the shift linkage and all pieces are moving as should be. Now I am really concerned that it is the drive shaft. I am very new to the "guts" of how the motor works and where the pieces are. Sorry for sounding foolish, but you guys are helping me narrow down where the problem lies. The question now is, Where is the drive shaft? do I need to pull the lower unit off? Thank you in advance, BassMaster
Joe Reeves
One more thing (Columbo!).... I've never run into a spun hub (slipping propeller) so bad that it wouldn't propel the boat at a low rpm, but that is a possibility.
However, do this, engine NOT running obviously)...... shift cable disconnected from engine. In neutral, turn the propeller by hand and take close notice of the effort it takes to turn the propeller. Now, put the engine into gear via the linkage at the engine. If you can still turn the propeller fairly easy but the effort just got ever so slightly more-so... yeah, that indicates a sheared driveshaft.
The driveshaft on that model would be a two piece driveshaft which is attached to the lower unit. It runs from the top portion being splined into the powerhead's crankshaft to the pinion gear in the lower unit. In removing the lower unit, the driveshaft comes out with it.
Now... back to the propeller question. When you encountered this problem, did the propeller turn and move the rig at a low rpm... or is it a case that the propeller action is as above (sheared explanation)?
Honorary Supreme Mariner
The JOHNSUKIS left the factory with a one piece driveshaft.---It may now be a two piece shaft.-------Pull the lower unit off and start investigation.
Stumpalump
Follow the procedure to drop the lower unit to replace the water pump. In the process you will disconnect the shift rod in the lower unit. Make sure that conections has not loosened up.
Joe Reeves
The measurement of the shift rod height, in NEUTRAL, from the top surface of the lower unit to the center of the shift rod hole is critical. The forgiveness of that measurement is only 1/32". No, I don't know what that measurement is, but if needed, I'm sure that some of the other members possess that figure.
BassMaster76
Wow! You all are a wealth of knowledge!! Thank you so much. I will tear into it and let you know what I find out. Thanks again.
