SoundWorks
Thread starter- Joined
- Jul 18, 2016
- 1
Hello Friends,
I have a "Bogging" issue with my 2004 Johnson 90 PLSSR outboard that has me lost.
Let me give the particulars:
I purchased a super clean 2004 Carolina Skiff 198DLX with the 2004 Johnson 90
The boat was a one owner unit. Total hours was 55 Yep, 55 hours on the rig. The boat was stored indoors and covered. I found that the fuel tank was stained with dried old fuel. I did not run the boat until I removed the 29 gallon OEM fuel tank and installed a OEM Carolina Skiff 13 gallon tank, New fuel line, New fuel separator, Primer bulb. The boat was tuned perfectly and ran well. This summer I encountered the loss of my VRO pump. A local Johnson dealer converted my 90 to a non-VRO pump with a factory kit. The boat ran fine for a few trips.
Fast forward to July 4 this year...
I launched the boat, it cranked up fine but seemed to have a rough idle. I had a little difficulty getting it into gear due to the rough idle. After running a few minutes, it smoothed out and at WOT ran 40 MPH with no issues. It ran about 10 minutes perfectly. With the throttle in the exact position, it started to lose RPM's and slowed to about 10MPH We pulled into a local on-water store and shut it off for about 10 minutes or so. When we returned, it cranked right up and again, ran flawlessly "almost" to the dock, the did the same exact thing. The fuel primer bulb was firm and pumping it had no effect. The motor was not overheated and water pump was flowing 50 Psi
Over the past few weeks I have done the following:
Checked every inch of fuel line
Removed and changed the fuel separator filter
Replaced the fuel filter & both gaskets at the fuel filter
Pressure tested the fuel system (no leaks found)
Checked the new spark plug gaps
Checked every electrical connection and the wiring
Checked my prop and gear case
This afternoon, I followed the exact route to see if it would run ok. And DAMN! It did the same exact thing! This time I turned around and I had to back down to about 2000 RPM's and it would run smoothly at 15 MPH
I'm not really sure but I'm leaning towards a coil or coils and power pack???
Can anyone give me some assistance before I spend upwards of $500 on coils and a new power pack?
Thanks so much!
Thanks so much!
