Thanks for any thoughts in advance.
As stated above... flashing a 32 error code (at least I assume it is.. I'm an Auto repair shop owner and this looks just like an error code for a car...) less than 100 hours on engine, running down the lake started to make a clacking/ticking noise and died... oil and everything fine, used only OEM oil. Timing belt is loose, a fair amount of minute metal around the top of engine (not a lot but more than I think there should be...) Motor starts but timing belt is loose and makes the slapping sound and it doesn't want to run... did it jump timing? maybe but if it's anything like a car it won't run well (and it doesn't but it did start and sputter...
) the tensioner hasn't loosened, yet the belt (which looks like new) is loose? The red warning light is flashing 3... then 2.. times and then pauses, leading me to believe there is an error code...
Any thoughts?
Thanks
Gary
Advanced Auto
Any thoughts?
Thanks
Gary
Advanced Auto
