I have a 2004 50 hp Johnson, only one cyclinder is getting spark. Thought is was a power pack so I replaced and still no luck, but my mechanic had a older one so he put it on and it started. CDI said to check the Trigger/timer base. The mechanic did that and said no voltage coming out of wht and blue wire and none out of grn and white wire. Then CDI said in order to know for sure you would need a direct voltage adapter. He does not have one, I have it narrowed down to the stator, timer base , or the rectifier, I think. but without that DVA tool I would have to buy Hundreds of dollars in parts and do elimination, and then have to return them if I even can. When the boat had trouble on the water and I finally got it restarted, it ran perfect so im not so sure its even the stator. Any help would be appreciated!
