2004 Johnson 115 saltwater edition J115PLSRC water pump issues
matador66
When I put the boat up for winter the pump was working fine. I got it out the other day and put the ear muffs on, cranked the motor and no water came out of the pee hole and the overheat alarm went off after a few minutes. i imagine the pump froze up or thermostat went bad. I don't know. The lower unit was replaced a year ago. Ordered a new water pump kit but unsure how to take the lower unit off. can someone help?
matador66
Would a bad thermostat cause water not to flow out the Pee hole and cause the engine to overheat?
Any suggestions would be appreciated.
matador66
well, I finally put in the new water pump and to no avail. it did the same thing. The old pump housing was melted pretty bad. I guess it is the thermostat. Any Ideas, folks?
Chris1956
Honorary Supreme Mariner
If the pump housing is melted, it is likely not getting any water. I would pull the water intake grates and see if you have a blockage.
